Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Learned by do'n twice
Bulldog and 2K primer Incompatible?
This is the third (and last) time this had happened to me. Painting a new bumper I first laid down a few coats of Bulldog and then a few coats of 2K high fill primer. After letting it dry overnight and wet sanding out the 2K (and letting it dry) , I shoot it with the base color (PPG Deltron 2000) and the paint crazes/crinkles up and looks like you took a piece of aluminum foil, rolled it up into a ball, and smoothed it out again. Had to strip the bumper back down to bare plastic.
Is there a known incompatibility between Bulldog and 2K primer? If not, there is now, at least as far as I'm concerned.
I'll never use 2K on top of Bulldog again.
jmd_forest
86 944 NA - Brought back from the dead
Old 10-04-2009, 12:49 PM
dkbautosports.com
962porsche's Avatar
bulldog has one use.that would be trash can filler ! its so temperamental its not worth using . i'm a glasurit shop and a rep came in and gave me a can to try insted of the glasurit adhesion promoter. i did it step by step by the tech sheet and it did the same thing to me . i washed it down and used the glasurit . like i always do with no problems . if it ant broke don't fix it !!!! I would get some ppg if your a ppg person . I my self i don't like inter mixxing brands becouse this is the kind of things that can happen .
Old 10-05-2009, 08:09 PM
