-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   DIY IROC RSR Conversion (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/502929-diy-iroc-rsr-conversion.html)
not_hans_stuck 08-10-2010 10:37 AM
Originally Posted by HelmetHead (Post 5492982)
Wow...just WOW! Iroc car came out Beautiful...and the blue Pantera is wicked too!
Need to get the Houston crowd motivated for a big fall get together!
Cheers!!!
Einar
Thanks Einar!
You're right about that. I still haven't seen your new car...
H
not_hans_stuck 08-25-2010 08:50 AM
OK. Here's an update. The car is back on the road. There's a punch list still - windshield wipers, mirrors, still needs another polish, few minor trim items, etc.
But, it can now resume it's role as morning starbucks-getter.
Stay tuned to this space, though. There's a couple of major projects coming up. First, it's getting an air-conditioner replacement. It will also get a complete suspension and engine makeover next. Probably starting in a month or two.
I don't want to hear any whining about putting an ac in the car. This is Houston, not San Diego, Denver or Seattle. It was 104 with 55% humidity yesterday at 11 in the morning. I am old and this is not a race-car.
not_hans_stuck 08-25-2010 08:54 AM
http://forums.pelicanparts.com/uploa...1282751563.jpg
http://forums.pelicanparts.com/uploa...1282751591.jpg
http://forums.pelicanparts.com/uploa...1282751615.jpg
I'll post better pics after I get some of the items off the punch list - like mirrors and polishing...
Hal
HelmetHead 08-25-2010 09:12 AM
Freakin Awesome! Congrats! Hmmm...Engine make-over...More HP??
joeporsche1 08-25-2010 09:22 AM
Nice ... didnt like the gt raciong kit did you youll be way happier with the steel
fenders for sure. SmileWavy
not_hans_stuck 08-25-2010 10:12 AM
Thanks. The fiberglass flares, in and of themselves, would have been fine. It was bad information on the bonding chemicals that did them in. I agree that the steel flares will be better though.
not_hans_stuck 08-25-2010 10:29 AM
Originally Posted by MichiganMat (Post 5479031)
Ok, awesome. Thanks for the response. A few more questions...
We're taking our car down to bare metal, most of the paint has been removed now while we do the ugly job of replacing rusted out panels. The car is basically sitting bare in the garage...
1.) Would you suggest sealing it with something while the welding work is done? Maybe a light coat of something? I haven't noticed any surface rust appearing but then who knows.
2.) Are all primers created equally or is there one you suggest using? My fear is that I spray with a primer that isn't compatible with the topcoat.
3.) What is your basic paint layup? Metal -> primer -> single-stage? Can I just spray down primer to the metal and be good? I've heard people use the term "epoxy sealer", stuff like that.
4.) How many coats of primer do you lay down?
Thanks for the advice man, this is really all new to me.
Sorry I didn't see this.
1.) I would suggest using a weld-through primer. I didn't though and it turned out ok.
2.) Here's something I learned. Use primer, base-coat and clear coat from the same mfg. Sikkens, Dupont, PPG, whatever - one brand all the way through.
3.) Single-stage paint sucks. It's from 1945. Use two stage - base coat, clear coat. The clear coat is like wrapping your car in super shiny armor. Primer on metal is fine. That's what it's for. Epoxy sealer/primer is typically high build. The high build primer is used to add more material and allow you to obsessively smooth sand the surface.
4.) Dunno exactly. At least four complete high build shots. Some areas were sanded and re-primed multiple times to get the car perfect. It's a show car paint job so it's seriously ocd. The reflection in the paint is sharp enough that you can read the spec plate printed on the overhead neon lights and all the reflections match up between body panels. It was a LOT of work. Months...
not_hans_stuck 08-27-2010 09:20 AM
Gillies 02-09-2011 08:25 PM
Very Interesting thread !!
carslutt 02-09-2011 08:33 PM
great thread
e p slick 10-19-2011 04:23 PM
Not Hans
Here are some old pix of 993 mufflers that I installed in/on my last V8 project. Pretty straightforward. Also attach image of my latest project of a 993 3.6 that I have just installed into my 86 Carrera. Your deal sure looks well done. Congrats.
EP Slick - Tucson
http://forums.pelicanparts.com/uploa...1319066423.jpg
http://forums.pelicanparts.com/uploa...1319066434.jpg
http://forums.pelicanparts.com/uploa...1319066445.jpg
http://forums.pelicanparts.com/uploa...1319066453.jpg
http://forums.pelicanparts.com/uploa...1319066461.jpg
[img]http://forums.pelicanparts.com/uploads19/EX1
not_hans_stuck 11-22-2011 10:22 AM
EP Slick - Tucson
Thanks Eldon!
That looks like a pretty good way to do it.
Hal
not_hans_stuck 11-22-2011 10:25 AM
Finally got around to putting the Carrera logo on it.
Here's the latest pics.
http://forums.pelicanparts.com/uploa...1321986251.jpg
http://forums.pelicanparts.com/uploa...1321986281.jpg
giovanni86 11-22-2011 12:14 PM
wow :) :) I like it!
1-ev.com 08-06-2012 02:17 PM
Cool build!!! Were you using black or white headliner? Txs, -Y.
not_hans_stuck 09-11-2012 04:53 PM
White headliner. I'm considering a fancy-ish tan leather interior. Something between hot-rod and Singer. I don't really know. I'm open to suggestions.
H
Diceman 09-11-2012 08:04 PM
Wow. I love it!
1-ev.com 09-12-2012 06:39 AM
Actually :D Sorry, I can see it on the 1st pic, I should be asking for pics of it :D Txs.
HelmetHead 09-12-2012 06:42 AM
You should check out Keystone Brothers over on Fulton street.. They stock EVERYTHING for auto interiors...We were just there looking for black leather material for our RS..It was really kinda cool when they brought out a cow sized hide to check out!
not_hans_stuck 08-28-2014 01:16 PM
MrShades 09-16-2014 08:36 AM
Great looking car and a job well done :)
Can you tell me the dimension of the rear Fuchs?
Ferrino 09-17-2014 03:45 PM
Great build! I'm also interested to know the widths/offsets of your wheels (the fronts look to have a lot of -ve offset) and where you bought the steel flares from? Thanks.
Arts911 10-31-2015 11:24 AM
Nice work !!!!
not_hans_stuck 05-01-2016 05:10 PM
Thanks!
gliding_serpent 05-30-2016 08:02 PM
what rubber "smile" did you use for the front bumper between the bumper and trunk/fenders. I also have Getty bumpers (basically MA shaw) and ordered a smile from Stoddard that I thought would work, but it did not.
I heard good things about the 964 smile, but wanted to verify what you used. And what did you use for the back bumper? (we have the same basically, but mine are narrow bodied).
http://i1168.photobucket.com/albums/...psq99crupr.jpg
http://i1168.photobucket.com/albums/...ps3rl3fdr6.jpg
mine are still raw... waiting for some actual hot sun for post-cure.
