Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
GaryR's Avatar
Send a message via ICQ to GaryR
Color over new undercoating?
I had the shop that fitted all my fiberglass parts and get her ready for paint clean and undercoat as they went along. He used a Wurth-type hard black coating as he knew I intended on paining the body color everywhere. The undercoat was done months ago and is perfectly clean. Should I use a primer before color or just drop the urethane right on it? I planned on trying a small area as i'm doing the engine compartment 1st, but figured many have been down this road.
Thanks!
Gary R.
Old 10-24-2009, 03:35 PM
dkbautosports.com
962porsche's Avatar
with out a wurth product # i'm not sure what was used ? if its chip guard ? then you would use the same sealer as you would when refinishing the rest of the car before you spray the top coats .
Old 10-25-2009, 06:48 AM
