Can anyone provide, or tell me how to locate, the measurements for the correct chassis alignment of an early 911?
I am replacing the front floor pan & eventually the front suspension pan. The car has been hit in the past resulting in a few spot welds breaking loose in the front end structure. I need to make sure that it is straight and square before welding in new metal. I seem to remember seeing something on the front suspension pan measurements and correct angles. Also, any suggestions on DIY chassis alignment methods would also be appreciated. Thanks!
Bondo sucks. |
dkbautosports.com
i have them . pm me a fax # or a mailing address . for what year 911 would you be needing it for ?
Done.
Thanks!
Bondo sucks. |
