Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
casperc's Avatar
Soda Blasting Question
Anybody have any experience or knowledge with/of soda blasting?
Old 04-06-2010, 04:46 PM
Aslet's Avatar
I got a soda blaster from Eastwood Garage to do mainly wheels. The compressor I have works, but it is so weak I couldn't do much. It is a 3.5HP 5gal compressor. I have been thinking about getting a two stage 6HP 80gal compressor to do painting with, and I think that would help the soda blaster a lot. There are also different grits of the soda media. Typically Porsche uses from real good and hard paints, so the larger grit may work better. On the cookie cutter wheel I tried to blast on, the clear came off decently, but the black paint was hard to remove. So the large grit and real compressor, I'm sure it would be easy.
What would you want to use it for?
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 04-06-2010, 08:06 PM
casperc's Avatar
Originally Posted by Aslet View Post
I
Anything you would use glass or grit media on, sheetmetal, suspension parts, wheels, engine case etc.
Old 04-07-2010, 06:24 AM
Aslet's Avatar
Just know that it is a gentler form of blasting. This makes if good for aluminum or around glass/trim. It may not be as affective on very dirty parts. Also for anything with rust, you can get a rust soda that has aluminum oxide in it. This will get off rust (or so it says), but will also be harsher (so may limit the use on soft metals).
My basic opinion is that if you want to get a blaster and have a compressor that is powerful enough to really runit, it is a very useful item. If you get the Eastwood Garage soda blaster, it also comes with the regular media blaster valve. So you could hypothetically switch between the valves and use it for both types of blasting...
-Randy
Old 04-07-2010, 11:02 AM
dkbautosports.com
962porsche's Avatar
yes alot of experience why ???
Old 04-07-2010, 02:09 PM
casperc's Avatar
Can you share your experiences, good or bad, do you recommend it as a tool?
Old 04-09-2010, 05:57 AM
dkbautosports.com
962porsche's Avatar
its all about what your trying to achieve ! soda blasting is the best thing when it comes to composite materails like fiborglass and carbonfibor also some aluminium parts . if your looking to blast rust off for get it ! you will need to use another media like plastic ,sand or black beauty . if i know what you need to blast and what shape its in i could help more .
Old 04-09-2010, 05:07 PM
casperc's Avatar
How about removing carbon from pistons and combustion chambers?
Removing paint and old Bondo from a motorcycle gas tank?
Removing Paint from alloy wheels?
Old 04-09-2010, 05:30 PM
dkbautosports.com
962porsche's Avatar
carb cleaner or lacquer thinner . i just remove the pistons turn them up side down and put it in a can with a little wash thinner (cheap home depot lacquer thinner ) in it . in no time at all the carbor will fall right off . take some aluminum polish buff the tops of the pistons and reinstall . plastic media blasting works best for alloy wheels and removing paint and body filler from metals . soda will remove the paint from the tank but not the body filler . when it comes to alloy wheels plastic media will leave little to no blasting pits that will sand off ez with a 220 0r 320 grit cut paper for refinishing or keep stepping down the grits of paper untill you get to 800 or 1000 and then you can buff them with a soft mettal polish kit . i get most of my blasting abrasives from AFI in wallingford
Old 04-10-2010, 06:07 AM
casperc's Avatar
RE:962porsche
Thanks for the tips, and good luck on your book, I'll buy one too, and a CD or DVD with video demos would be a good accessory to the book.
Clarence
Old 04-11-2010, 04:48 AM
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by casperc View Post
How about removing carbon from pistons and combustion chambers? Works fine
Removing paint and old Bondo from a motorcycle gas tank? Like shooting BBs at an aircraft carrier - not gonna happen
Removing Paint from alloy wheels? See above, times 10 (if it is decent paint, that is. It will take off Krylon)
I love mine - it is good for some things, not others.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-22-2010, 02:49 PM
