Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Suspension Paint Preferenes
I am in the process of refinishing some front suspension parts and am stuck on the paint. It looks like the factory used a semi-gloss black paint. Does anybody know what kind of paint this is or where you can get it? Also, any thoughts on powder coating this type of part? I am thinking it would probably be better to stay with the original factory method but I don't know. What do the experts say?
Rich
87 Coupe
Old 12-19-2009, 10:39 PM
robmog's Avatar
2 choices semi gloss paint vs. powdercoat.
paint pros: repairable/recoat; cheap; correct
cons: less durable
powdercoat pros: extremely durable
cons: not repairable; thick, can affect clearances
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 12-20-2009, 09:03 AM
dkbautosports.com
962porsche's Avatar
i use SEM's rust-shield alot . its a dead nuts catch to the OE coating . its a single coating application meaning no priming is needed . just like OE . it has excellent corrosion control being cromeated . if you mix the flat black 8 to 1 with there hardener it will match the gloss to a tee . it has the same mill build as the OE finish with the same chip resistances (with proper prep ) get a TDS technical data sheet . it comes in QTS and GAL. and at about 60 dollars a gal. its cost affective .over the last 30 plus years i have been doing this crap for a living. i have tried most all products on the market and i keep going back to rust-shield .
Old 12-20-2009, 09:11 AM
I knew there must be a downside to powdercoating but I just didn't know what it was. Now that I know, I think I will go with the recommended SEM paint. I am in Southern California so I hope it is available. The Government around here would like you to color your car with crayons. Thanks for the replies, problem solved.
Rich
87 Coupe
Old 12-21-2009, 02:11 PM
dkbautosports.com
962porsche's Avatar
the epa did the same thing to us here in ct. i had to change over to water colors . is not that bad .
Old 12-21-2009, 02:42 PM
