Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
ratpiper71T's Avatar
Equipment for painting/ body work
Getting ready to buy a compressor for the garage. I haven't started the resto yet on the 911t. My work on this project won't start for quite a while so as for now I'm educating myself on what I need. I do have some painting and bodywork books which explain a little. However the total setup and what works and doesn't work together isn't completely clear.
I have a few questions first as to the equipment necessary to be able to do some body work and painting. If I misuse some terminology forgive me as I think I may hold a few misconceptions about the capacity of the equipment in general,.. i.e.- cfm, psi, etc.
My assumtions are that I probably want to go with hvlp, unless someone can verify that the eastwood concours type setup ( is that lvlp?) is even worth trying.
I scored from the neighbor- 3 Hankison airdryers with the following specs (actually it's 2 working dryers and the other one is questionably functional- according to him-he had it for parts for the other two if needed.)
HANKISON COMPRESSED AIR DRYER
Model 8010ss
Rated Capacity 10 SCFM @ 100 psig @ 100F inlet air
MWP 175 psig
Min/Max ambient 35 F (2 C) / 110F (43 C)
VAC 115
Phase 1
Hz 60
Unit Fla 3.3
Compressor Fla 2.9
Fan motor amps 0.5
Max fuse/ckt breaker size 15
Fan motor watts 4
Min/Max volts Min - 104 Max 126 vac
Compressor HP 1/6
Compressor LRA 18
Min. ckt ampacity 4.1
Refrigerant R-12
Refrigerant charge 6.5 oz
Refrigerant suction pressure 33 psig
Factory test pressure 235 psig Hi/Lo refrig. side
Now what stands out so far to me is the 10scfm and the part about r-12-am I going to to b able to get this recharged somewhere?, will it even hold a charge? Is the part about the scfm limiting me to that as output volume?
OKAY the compressor I'm thinking of is and IR 5hp 60 gallon single stage-18.1 scfm @ 90 or a 20gal 2hp single stage 5scfm @90. THe smaller compressor was if the eastwood concours type gun (lvlp?) route is possible.
So numer one were the airdryers a waste of money? or can I use them?-with which setup? which compressor is the best choice? NOt a big loss if the dryers are junk I hardly paid anything for them and a lincoln welder with gas setup, clamps auto-dark helmet, tools and more.
Someone set me straight, please.
Mama lock your daughters up that wild bunch is back in town!...And them little girls get frisky when they hear that race-car sound!
Old 02-16-2010, 09:42 AM
rw7810's Avatar
I've got that IR compressor you are looking at and bought mine for the same reason. You can see pics of my restoration on this site. I also bought a Devilbiss 670 Plus gun.
I didn't have a dryer like you have and will defer t oothers. I used the standard water seperator and "toilet pare roll" dryer and it worked fine down here in houston.
Robert Williams
70' 911T
Old 02-16-2010, 03:00 PM
Thanks, Bob.
I guess you mean th 60 gal., right? yeah, it looks lie a lot for the money-every site i've seen it on has nothing but good reviews. Can you provide a link to the dryer you speak of?
HOpefully mine aren't total trash. I was excited when I got them. From what I've been told most of the problems people experience with paint prime etc. have a lot to do with water in the air.
Anyone else?
Old 02-17-2010, 09:03 AM
rw7810's Avatar
Many places sell these, called Motor guard: Motor Guard M30 Sub-Micronic Coalescing Filter 1/4 NPT
This is a great site and forum for anyone wanting to do restorations, paint and body work, etc.:
Autobodystore Forums
Robert Williams
70' 911T
Old 02-17-2010, 10:48 AM
