Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
pontifex4's Avatar
Unusual 944 body question
This likely isn't the ideal venue for this thread, but it wasn't all that welcome in the last place I tried, and I really admire the skill demonstrated in the projects I've seen here.
Basically, in the image attached, the stereo installation I'm considering would require the round cut-out to be moved higher (to roughly where the red line is, give or take):
The best guidance I've heard so far is that the area around the door is designed to preserve the door's shape in a collision, so that it will still open. With that in mind, what are your thoughts on cutting this opening, then welding a plate over the area with a 3.5" hole in it?
Thanks in advance!
Charlie
'99 996 C2 6 speed - Arctic Silver
Old 06-04-2010, 09:08 AM
dkbautosports.com
962porsche's Avatar
being the current owner of 8 porsches and 5 of them 944's ( 944's are like pop corn you just can't have one ) and a 30 year body and paint person i would say its fine to cut that out ! just DO NOT cut into the sides of the boxed area . if you ever had a 944 cut open there you would see just how its made and how strong it is .
Old 06-04-2010, 08:03 PM
pontifex4's Avatar
I really appreciate your perspective. I felt around in there and the sheet metal doesn't feel as though it touches the braces behind it in the area I want to cut. I will stay well clear of the boxed sections.
What I'm considering is trimming out a rectangle, then welding in a plate with a 3" circle located about 1.25" higher, instead.
Again, thanks for your help.
Charlie
Old 06-04-2010, 08:31 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Charlie..
Is that "revised" location to accommodate a speaker?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 06-04-2010, 09:56 PM
pontifex4's Avatar
It is, indeed. I'm trying to minimize path length difference in the mid range drivers of a Dynaudio 3-way set:
The challenge is in positioning the speakers such that they work together without being in the way, and if I can recess them into that void a little more, I won't be kicking them every time I get in or out.
I'm proceeding with caution...
Charlie
Old 06-05-2010, 09:07 PM
