Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
How much paint? (quantity)
How much paint should I estimate for a full paint job. That is; how many gallons?
Old 12-24-2010, 07:13 PM
dkbautosports.com
962porsche's Avatar
i can't tell you with out knowing what color ? single stage or base/clear ? just what kind of car are you painting ? will you be painting the jams, under hood, under side of lib ,inside of doors ? most 911 size cars will use from 3 QTs to 6 QTs of color and from a gal of clear to 7 QTs of clear .
Old 12-24-2010, 07:46 PM
Thanks-- I have never painted a car and had not idea how many gallons it might take.
Old 12-24-2010, 08:03 PM
Fleabit peanut monkey
Bob Kontak's Avatar
962Porsche - You are a wonderful resource for us noobs and semi-noobs.
Please help me understand the quantities better. Are the quantities you mention mixed with reducer and/or hardener to arrive at the total?
The fat end of your range just seems like a whole lot of paint. If you are painting a naked tub (floor, pan, inner fenders, etc) in it's entirety then the numbers seems to fit.
Old 12-27-2010, 02:12 PM
dkbautosports.com
962porsche's Avatar
Bob no that would be colors that are not mix for spraying or non sprayable QTs . again it depends on the color your spraying , that paint line , if its base /clear or single stage , if its a HVLP , HVLP compliant , or just a old HPLV gun . there are so many factors that come into play . take the color black i can spray a hole car ( out side only )with about 2.0 QTs of color ( not reduced ) reduced 2 parts color to 1 reducer it comes out to be 3 QTs mixed color . take the same car and say your painting it orange you will need allot more color say about 4 QTs unmixed to start with . the main reason is its coverage ! colors like yellow and orange are very pour hidding colors . this is one reason i tell people to use a sealer 1st before you start laying down your top coats . if you sand throw an edge and you just try to spray over it it will take many coats of base color to cover the sand throw with a color like orange . also a sealer will help to stop it from sinking in after the paint job is finished .
Old 12-28-2010, 04:35 PM
robmog's Avatar
on my 72, bare metal:
i used 6 quarts epoxy primer, 2 quarts filler primer and 6 quarts single stage finish.
i sprayed the whole car except interior in primer, only the exterior in finish
i used an old hplv gun and put down 3 coats finish.
all PPG
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 12-28-2010, 04:47 PM
Bob Kontak's Avatar
OK - Thanks to you both - 962Porsche and robmog - When I painted my 81 in red with single stage Glasurit I painted directly over the good existing paint as instructed by my jobber. I used three quarts and had a little left over. Coverage is the issue and I don't have enough experience with different colors to know that.
All the best and Happy New Year.
Old 12-31-2010, 01:43 PM
