Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Will 76 heater tubes fit in a 66?
Does anyone know if i can use a set of heater tubes from a 76 that i can cut up,and use them in the 66 SWB that im building, and how about the rear seat
buckets ?
Old 10-24-2010, 02:27 PM
300hp 1800lbs is the goal
pksystems's Avatar
The heater tubes did change sometime after '66
In this thread you can see how he made new heater tubes for a '69 which look different from what was in my '66 912
Page1, and 4 show what he did.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/545166-restoration-my-69-911-a.html
Here's a shot of what the inside of my rockers looked like:
Since I closed up the footwell heater with the rollcage mounting plate, I just made a new tube out of some thin galvanized (24-26ga) ducting from a house. Wrapped it around a piece of 2" pipe, folded the lip over, and did a bunch of spot welds. I fit it over both ends of the original pipe where I cut, and crimped it down tight with a hose clamp. I put a couple spot welds on the rear section to hold it in place, then coated the joint with seam sealer. I couldn't get my welding tip close enough to the front attachment, so I just tightened the hose clamp, left it in there, and then coated that area with seam sealer. It's not pretty, but you won't see it.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 10-24-2010, 10:53 PM
I used a Thrush glasspack muffler for mine...works well
Old 10-25-2010, 05:33 AM
Thanks guys , but i have a 76 to cut up, should i spend the time to cut them out and with a little finess make them fit?
Old 10-25-2010, 02:13 PM
pksystems's Avatar
It took me forever to get all the spot welds drilled out around the footwell, thing, which is part of the tube. Probably easier to just patch sections if you have holes. If you have a '66 it's probably not leaking from the tube. It's probably leaking from the bottom corner of the torsion tube area. I had a hole right into the heat tube in that area on my '66, on both sides (low spot that isn't painted, heated air = moisture)
That is the inside of the heat tube you can see in that picture. You won't have much heat at all if there is a hole in that corner. The heat tube inside my rocker, was surface rust, and looked pretty bad, but I cut it out anyway so I could clean up the inner rocker area better.
Old 10-25-2010, 02:29 PM
wish my car looked that good , picture a 911 with nothing usable below the doors,oh ya it also needs fenders,doors, quarters rear seats pans, rear deck lid under the glass , all the ussual front stuff, floors inner/outer rockers complete heater tube ,i know this becuase i can see the threw the hole in the rockers.
so i bought a good roof and a ownership.
Old 10-26-2010, 05:57 PM
nice car just in i like the muffler idea
Old 10-26-2010, 06:45 PM
