Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Decolliber's Avatar
why polish?
Does car polish really preserve the paint or does it just make it look nice? I am thinking I ought to polish before winter but feel lazy ...
John C
1988 911 Carrera coupe
2002 BMW 530
Old 11-14-2010, 09:41 AM
Polish does nothing to preserve paint. Polish polishes. Polish is an abrasive and takes off a micro fine layer of paint (the oxidised surface) revealing the new paint underneath. In fact polish will reduce the life of paint as it is removing thickness. Polish enough and you will wear right through the paint layer. Protection comes in the form of a protective coating such a carnuba wax. Some of the new polymers even have UV inhibitors which slow the oxidation on the paint surface.
Old 11-14-2010, 03:16 PM
haycait911's Avatar
waxing will give some protection, maybe. polishing is for removing defects, only when needed. if it's modern paint, just keep it clean. if original a waxing is OK. key is making sure the paint is CLEAN first. I like a clay bar, then thorough washing then a good wax.
Old 11-25-2010, 12:44 AM
Banned
I have a 85 911-what is the best wax I should use to get the swirls out of the red paint? Somebody told me to use awax that starts with g but I forgot the entire name. Anyone know what wax I should use?
Old 05-26-2013, 06:06 PM
Try lusso oro. It's amazing
Old 06-04-2013, 12:28 PM
A wax in its most pure form will not remove swirls. Some waxes on the market now have cleaning agents which can minimize the swirl look, but to fully remove them, the surface needs to be treated correctly. A thorough cleaning, A clay bar to remove any surface contaminants, followed by a compound or series of compounds. This is the critical step as there are so many variables. The abrasive level of the compound/polishing agent, the rpm of the tool being used, even the type of applicator being used all affects the result. The last steps can include a sealant followed by a wax to protect it. If you've not done this before, may want to enlist an area detailer who can properly do the job with the correct tools.
Old 06-09-2013, 06:15 PM
Dial 911
A horse with no name's Avatar
Hi...As a finishing polish, it's hard to beat 3M's Ultrafine machine polish...Most auto body shops use 3M's products from their masking tape, sand papers, including their
"Perfect-It" line When finished polishing just use a high quality carnauba car wax such as Meguiar's Gold. It goes on very easy and comes off the same.
I see that 3M bought them out a couple of years ago, so I presume that some of their new products are either similar or the same.
3M Perfect-It Ultrafine Machine Polish, 16 ounce, 39062
High Performance Compounds & Polishes - Compounds, Polishes, Glazes - Products
You will like the ease of using it especially the finished job ..You'll pay more for it because it is a quality product.
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 06-10-2013, 01:42 AM
