White Wax Removal From Rubber
Whats the best cleaner to use to remove wax from the stone guards and other bits of rubber/black plastic?
1987 911 Convertible 2006 VW Beetle Convertible 2003 Dodge 1500 1966 Impalla SS Conv. (departed) |
I am trying to find a solution for was residue removal as well.
I just purchased a very nice RS America. Previous owner waxed it often but their is residue in every little crack and crevice. What is the best way to remove the residue? Is their a solution that will break it down? Thanks John
John www.P1-MotorSports.com |
I spent the day with a bottle of cirtus degeaser and some rags. :-)
It worked very well. Still need to go back and touch up some spots. The wax residue was heavy on this car. One suggestion. Pour some citrus degreaser into a smaller container because if you keep dipping your brush into it it will become dirty. Have fun!
Mothers Back To Black works well also...
Tim 87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost.... Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims. |
Ray H. 1979 911SC Coupe 2000 986 |
19 years and 17k posts...
I use Griot's "Dried On Wax Remover" and it works very well. Give it a minute or 2 to work before wiping it off...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Charles Goodyear is also responsible for the Blimp that flies over football stadiums. There were originally two types of lighter than air craft. The A - type was rigid and the B - type was limp (combine B - limp and you have Blimp. Cool!). Expect un-vulcanized rubber to be a mix of very long limp chain molecules like a bowl of spaghetti. That makes them rather flexible until stretched taut like a rubber band taking out all the slack. Vulcanized rubber added sulfur to the mix to help take out the slack. Rubber bands can be manufactured by dipping a rod of the correct diameter into a batch of (latex) rubber and letting it cure. The rubber bands can then be cut from the rod like so many O'rings (side by side). Early un-vulcanized tires often punctured (even several time during a long trip). Some gave up and stuffed them with grass, etc. just to get back home. I don't believe that Goodyear invented the blimp but they did use it effectively for their advertising.
That is very cool!
Not sure what it has to do with removing wax, but very cool nonethless. angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
I think microfiber mitts/towels and wool mitts are both good options.You should ALWAYS pre-rinse the car with high water pressure (as high as you can) to blast off the bigger stuff first.
Alps Adventurer
Next time, use less wax and use it where it belongs.
