Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Paint for Misc Black Sheetmetal Parts?
What suggestions do you have for paint for the miscellaneous black sheetmetal parts I'll need to be cleaning up (engine sheetmetal, seat brackets, pedal cluster, etc.)? Some of the stuff has light surface rust, some just flaking paint, but POR seems to be overkill and Rustoleum rattle can seems a little too temporary. Anything suggestions?
Old 12-20-2010, 06:06 AM
tobluforu's Avatar
If you have a powder coating co. near by, have them do it.
Old 12-20-2010, 06:19 AM
yel911's Avatar
Look up "SEM" I believe. My paint shop has them in spray cans and comes in different colors. I did all the parts you mentioned including suspension components with it. Applies directly to metal, no primer. I do use high temp paint for engine sheetmetal though....
74' 911 w/3.2L (sold)
95' 993 C2 Triple Blk Cab.
02 Honda Superhawk (sold)
2018 Toyota Tundra Limited
2004 CRF250X
Old 12-20-2010, 09:04 AM
yel911's Avatar
Try this link:
SEM, trim black, SEM paint, SEM adhesives, SEM preps & cleaners, dual-mix adhesives, leather coatings, vinyl coatings, sure-coat, color coat, aerosols
2004 CRF250X
Old 12-20-2010, 09:06 AM
eastwood rust encapsulator
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 12-20-2010, 05:20 PM
Retired Member
Charlie V's Avatar
I used a local u-blast sand blaster - hourly rental at a very reasonable rate. Then rattle can primer and paint. Did this about 4 years back and still looks acceptable.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 12-20-2010, 08:50 PM
dkbautosports.com
962porsche's Avatar
sem rust-shield . i use allot of it in my shop . they stopped selling it in spray cans ! but if you want to use it and don't have an air compressure order a preval spray kit . there only about 15 dollars and take the place of a spray can . if you use rust-shield get flat black and use there hardener mix it 8 part black to 1 part hardener it will make the shine a semi gloss and match the OE gloss to a tee . rust-shield is a one step DTM coating so you don't have to prime any parts 1st . if you do go with the preval system you will also have to add in some enamel reducer so the mix will be 8 to 1 to 1 reducer . get a fast enamel reducer this will help in keeping a good shine to the finish .
Old 12-20-2010, 09:44 PM
