Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
75 carrera, sunroof rust
The drain tubs for the sun roof pocket did not drain du to blockage. The whole sunroof assembly(pocket and drain tubs) is badly rusted including a hole in the roof(back right corner). I have a replacement roof(sunroof compleate). Has any ever replaced the sunroof assembly by way of drilling out spot welds or should I replace the entire roof?
phil
Old 12-16-2010, 06:51 AM
With both repairs you would be removing the headliner. With just replacing the sunroof you could leave the the glass in - but I'm thinking you would have a ton of mud on that roof by the time you were done. . An outright replacement of the roof at the pillars means you need to pop the glass - but leaves you with a small amount of body work. If it were me - I'd replace the entire roof. Also - while measuring, cutting, and fitting the roof are pretty straightforward jobs - you better make sure your welding skills are up to the task.
Good Luck
Old 12-16-2010, 08:31 AM
