Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
83 911 Production Cab #10
JJ 911SC's Avatar
Question Engine Shroud Painting
Can it be painted? I would like to go from black to red (outside only).
Who Will Live... Will See
Old 01-22-2011, 03:19 PM
silver911rdb's Avatar
I know some people will roll their eyes but I redid an engine some years ago and used Krylon paint straight from the can for the shroud. I can't remember the color code but it was a real close match. I had the engine for a few years prior to selling it. The paint never peeled and looked factory. I did prep the shroud very well prior to painting.
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 01-22-2011, 05:10 PM
JJ 911SC's Avatar
Thanks Rich
You can almost feel the air movement from all the Lol...
I don't have the matching problem. I'll check with a local paint shop where I know the co-owner. I'll let you know if she does a face.
How did you prep, sanding or just cleaning?
Cheers
J.J.
Old 01-23-2011, 03:54 AM
As I recall I just lightly sanded the shroud an cleaned it with some wax & grease remover. I think the important thing is that you sand it to give the paint something to grab onto and of course cleanliness is probably the most important.
-Rich-
1984 911 Track
Old 01-23-2011, 06:16 AM
JJ911SC,
Make sure you clean and degrease it top and bottom well before you scuff. Grease is your enemy on that part. There are lots of microscopic nooks and crannies to catch grease and dirty. When you think you have it good and clean do it one more time. Lightly scuff the surface, 3M green pad or 200 wet dry paper should do the trick.
Old 01-23-2011, 07:47 AM
JJ 911SC's Avatar
Thanks Guys
If I remember correctly from my Navy days, we prep for 6 days and painted on the 7th day.
Old 01-24-2011, 05:11 PM
I have used Krylon's Banner Red for two shrouds. The color and paint was recommended by Henry Schmidt at Supertech somewhere on this board. I found the paint and the color to both be perfect.
Rob Richardson
1974 911S
Carbed RS Clone engine
Turbo flares
2009 Carrera S - Porsche Racing Green, PDK
Old 01-29-2011, 09:19 PM
Originally Posted by JJ 911SC View Post
Thanks Guys
That sounds about right.
Old 01-30-2011, 03:52 AM
