Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
WTB manual for 89 cabrio roof mechanism repair
My roof is acting up and I need a manual that covers the electric motor/mechanism for my 1989 911 top. Bentley is lacking for cabriolet info.
Any help is appreciated.
Donald
Austin, Texas
Old 02-10-2011, 12:12 PM
Fleabit peanut monkey
Bob Kontak's Avatar
This website allows you to download the factory manuals for free. EDIT #2 - THE 84-89 MANUAL IN THIS LINK IS THE BENTLEY MANUAL AND NOT THE FACTORY MANUAL. SORRY - I DID NOT KNOW UNTIL I DOWNLOADED IT COMPLETELY.
However, I have tried loading the 84-89 manual (about 300MB) and have not succeeded yet. I get over a hundred MB of data then the download stops. I got the earlier ones no problem. I would try it at different times as there may be bandwidth issues on their end that kicks you off?
Manuals
Edit #1 - I finally got it to work. Use internet explorer and go into task manager(control alt delete) Find IExplorer under processes and set the memory priority to high. (right click on the process). Shut everything down but the download window and then let it alone for a while. After you finish set the memory priority back to normal.
Old 02-11-2011, 09:52 AM
Hi Bob,
Thanks again. No worry's on the manual. BTW- I'm on a MAC.
Old 02-11-2011, 12:21 PM
Bob Kontak's Avatar
A MAC raises your street cred.
Wonder if the earlier manual would give you some tips? It is the factory manual but I know nothing of changes re the cab top.
Old 02-11-2011, 04:00 PM
Bob Kontak's Avatar
Here is the parts diagrams for the 84-89. It is from Porsche's website.
http://www.porsche.com/all/media/pdf/originalparts/usa/911_USA_87_89_KATALOG.pdf
And a few links to check out - no diagrams or manuals
Power cabriolet top issue.
'87 Cab top won't go down
Driver side latch on 1988 cab top
Electrical and tech diagram for Convertible top
How does the @#! cab power roof work?
Automatic cabriolet top problems
Old 02-11-2011, 04:18 PM
Bob,
Again, thank you! All very helpful. For some reason the pdf won't open but it is probably on my end and am investigating.
db
Old 02-14-2011, 09:33 AM
Bob Kontak's Avatar
Drill down through this link. Pelican Parts Porsche Parts Diagrams and Locator
Look at around page 328 of 474
Old 02-14-2011, 11:24 AM
Thanks for the help ALL! See links for your roof woes HERE
Hi Donald,
Try these links. I uploaded them to google docs. At top left (under file menu) should be an option to download the document. See if that works.
https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B04ScZX 235LcYjY1Y2Q4MTMtYzVlMC00YjU2LTk5ODctMjg5MzA5ODI2Y TFi&hl=en&authkey=CJ-OjuoL
https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B04ScZX 235LcYTdiMTM2OWItM2E3MC00OWRhLWI5MGEtYTVmNGY2ODczM 2M2&hl=en&authkey=CJn7qt8N
Kyle.
Old 02-18-2011, 11:39 AM
Is the 86 and 89 tops similar?
Lorne M.
83 SC
Old 02-18-2011, 02:25 PM
