-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   Outer Window Seals (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/611244-outer-window-seals.html)
Sip 05-29-2011 06:02 PM
Outer Window Seals
Can someone please provide some help on installation of new outer window seals? I removed the old ones relatively easily prior to repainting the trim and am having difficulty installing the new ones. Is there a trick? Thanks!
Sip
fred cook 05-30-2011 04:42 PM
outer window seals.......
The "fuzzy" seals at the bottom of the windows are something of a pain to install. I just did this and used a wide paint scraper to put pressure on the mounting pin without bending the seal out of shape. I used hand pressure from the handle and pressed on the bottom of the scraper with a stout screwdriver in order to get enough pressure on the seal so that the pins would pop into place. Be careful to not press against the inside of the door slot or you might bend it. Before starting, make certain that the holes are clear of the old pins as they can pull out of the old seal as it is being removed. Good luck!
Sip 05-31-2011 09:14 AM
outer window seals
Thanks much
