What is the most simple way to fix this?
I have a '74 that is pretty solid other than these two places. Right and left front fenders at the rocker panels. I know I have to cut and weld new metal. Is there a place I can source just the lower portion of the fenders or do I have to fabricate from scratch? [IMG]http://i226.photobucket.com/albums/d...h/P1040532.jpg[/IMG]
[IMG]http://i226.photobucket.com/albums/d...h/P1040533.jpg[/IMG] |
I'd say the first thing you should do is strip the area to see how extesive the rust is. It may be possible to just cut out the area around the rust and patch in a new piece. That would be the easiest assuming the rust is just in the area of the visible bubbles in the photo.
Not trying to be a pain, but are you sure that is all you have?
By the way, these pieces are available through our host, who sources various sheet metal parts from several suppliers - Dansk, Restoration Designs, and Porsche.
Ask someone parting out a 911 to cut this out for you - cheapest way to get the sheetmetal you need.
Look underneath that area, there should be a drain hole... see if they are plugged with something.
thanks, guys. I'll find out the extent of damage soon.
| All times are GMT -8. The time now is 10:54 PM. |
