Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
wing removal
how hard is it to remove the wing of a 71 911 targa.and how would you go about it
Old 07-23-2011, 01:00 PM
Bird. It's the word...
Fishcop's Avatar
It's not a huge job.
Start by removing the headlight, indicators and horn grills, and wiring (also ariel/fuel filler where necessary) - there is a hidden bolt behind the horn grill and another up by the windscreen scuttle panel you access through the open door. Undo the remainder of the bolts inside the trunk and down the fender support panel in the rear of the wheel tub. There is a bead of dum-dum between the fender and the tub which will reluctantly release with a pry bar. Carefully pull the fender away...
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 07-25-2011, 12:22 AM
