eurathane primer compatability
im looking at ordering a single stage paint online. i have omni mp282 eurathane primer surfacer on the car. does anyone know what topcoat would be compatible or does it not matter.
thanks ps any recommendations for online paint suppliers?
76/3.0 tarcabvertible 64 corvette conv. 72 Alfa GTV 79 Jeep Cherokee Chief |
Fleabit peanut monkey
Here is some reading - I don't know enough to offer good advice.
omni mp282 sv high build primer surfacer & dbc |
dkbautosports.com
you can top coat any product ( primer or sealer ) that has been catalyzed ( that has a hardener added to it ) so you can pick any brand of paint to go over your primer . but i would stay with one product line but that is not to say your going to have a problem if you use an other makers top coat . this brings me to the ordering paints on line . 1st by mixing up product lines if some things goes wrong who do you turn to for help ? the maker of the primer the maker of the sealer or the maker of the top coat ? 2nd of some thing goes wrong and you ordered it on line what kind of tech support will they give you ? if you buy it from your area jobber ( paint store ) they are there also to help . you can get tech sheets from them and ask quastions ( YOU SHOULD ALWAYS GET TECH INFO WHEN YOU BUY PRODUCTS LIKE PAINT) . there really is no cost savings if you buy paint on line .
