Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
tharbert's Avatar
Fender Joining panel
I purchased the Restoration Design fender joining panel a while back. I'm to the point of placing and attaching the panel. I searched around here for a "how to" but didn't find anything. So, I read up on other posts and came up with a game plan.
Before:
Current: So I've fixed up the fender well metal and replaced the bottom half of the door hinge panel. I've since finished welding the rest of those spot welds::
Now I'm on to replacing the fender joining panel:
I mounted the panel to the fender. Then I mounted the fender to the car and roughly aligned the fender to the hood and window jamb area. Then I scribed the location of the panel as it sat in the wheel well. I removed the panel from the fender and afixed it to the wheel well with 4 temporary metal screws. Now fixed more firmly, I remounted the fender to double check and everything still aligned OK.
So the panel and fender are prepped with weld through primer. I need to drill some holes along the panel for faux mig spot welding and I'm ready to weld:
72 911T 2.4 MFI
06 Grand Touring Nissan 350Z
13 Escape SE 2.0
06 Kaw KLR-650A
10' Madone 5.2/17' Lynskey ProCross
Old 11-26-2011, 04:42 PM
E Sully's Avatar
Looks good so far. I will be the doing the same repair on mt 73.5 soon.
Ed
1973.5 T
Old 11-27-2011, 07:22 AM
cnielsen's Avatar
Looks good, I need to do this repair as well. Were you happy with the fit of the replacement panel?
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 12-04-2011, 12:04 PM
tharbert's Avatar
Yes, the panel fit well. I hope the rockers fit as well as this panel.
72 911T 2.4 MFI
13 Escape SE 2.0
06 Kaw KLR-650A
Old 12-13-2011, 01:46 PM
