-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   Local Rust Pits - rust removal and primer questions (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/647530-local-rust-pits-rust-removal-primer-questions.html)
VFR750 12-28-2011 10:37 AM
Local Rust Pits - primer questions - edited
Here is my new Winter Project:
http://forums.pelicanparts.com/uploa...1325096642.jpg
Not as extensive as others, but it needs to be cleaned out.
OK, I get it... new topic.
Rust is being removed by a small grinding wheel and carbide burr. The general surface rust was scuffed off with sand paper, but the pits! Ugh they were deep. So they had to be ground out. I have time and the deep pits are only in a few locations thankfully, so going the sand blasting route is a little overkill.
Looking at the posts and the 101, I'm still a little confused since most posts refer to things like "DTM" "RM" "EP" and other abbreviations that just make it hard to figure out what is being refered to. I've done a lot of searching but without a spreadsheet, I am losing track of all the suggestions. Guess I need a spreadsheet...
What is DTM? and Why is it good?
VFR750 12-29-2011 07:22 AM
Oh, DTM = "Direct to Metal"
RM = R-M a brand name...got it.
drcoastline 12-29-2011 12:57 PM
EP= Epoxy Primer
Good work Grass Hopper you learn very quickly.:D
rw7810 02-25-2012 09:40 AM
Mike - PickleX20 is a good rust converter product you could also use prior to priming. Go here to read about it. I used on my repaint as is Fishcop. Autobodystore Forums
