REar quarter windows removal
Been told two different ways to remove non opening windows for paint prep..Friends either givign me too much credit or ??
![]() Can any one help walk me througf hthis procedure. 78 SC Thanks , Terry
TOT |
If you give me a call, I can talk you through it.
John John Esposito's Porsche Repair North Hollywood, Ca. 818 469 1811 |
push hard on the glass, from the inside in the lower front corner. it will pop out. then just pull it out.
Work in Progress
From the inside of the car, I used a flat screwdriver and lifted the rubber moulding over the metal pinch weld. Once I got all the way around the window it came out without a problem.
You can use a towel around the screwdriver so you don't scratch the rubber molding.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
To remove mine, I just laid down in the back seats, 2 feet (No Shoes) against the inside of the window, and a friend outside to catch the window. Took ~1 minute/side, and didn't damage anything on the way out.
They install dry, so don't put any sealant around the edges, or you will have a hell of a time the next time they need to be removed. Use clothes line or similar size nylon rope and run it around the inside of rubber seal. Partner is out side holding window in position, pressing in and you pull on the two ends of the rope. This will contract the rubber seal and window should pop into place. Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
