-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   944 stone guard? replacement? (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/677009-944-stone-guard-replacement.html)
James Chimney 05-10-2012 07:15 AM
I am re painting my 944 and doing a little at a time, this is the area under door and lower fenders that have this "Bubble, paint, sticker" any one know how to replace this or should I just grind it off and repaint?
962porsche 05-10-2012 11:30 AM
are you talking about the chip guard ? if you are there is an ez way to remove it but it will be the cost of a air tool to do so . if you don't want to buy the air tool you can grind it off but it's a PITA .
once you do remove the chip gaurd you will want to spray down a coat of etch primer or epoxy primer to cover any bare metal spots . then let that dry and red pad the E-primer . and spray on your new chip guard . i like to use the U-POL gravi-tex chip guard it matches the same texure that porsche has . when it comes to painting time you would want to just spray a coat of sealer over the chip guard . ifyou prime over it it will take some of the texure away and you might not want that ? once you spray sealer you then can go right to you top coats wet on wet .
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
