Paint shot - help me protect the metal
I bought my '80 911 SC three years ago and I don't know what it has been through, but the paint is for the most part in a really sad state, with tons of chips and scratches.
Up until now I have had the car in a garage when not driving it so the state of the paint has not been a real worry, and I don't mind the look. Since a couple of weeks, however, I no longer have access to a garage so the car is outside 24/7 and I'm a bit worried that it will start to rust due to lack of protection. Obviously, a full respray is the only thing that can really sort it but I don't have the resources for that at the moment so my question is (finally =) if there is anything I can do about it myself in the mean time? I'm really only interested in protecting the metal and to not do something that will aggravate a later restoration/respray. Finish is a low priority. Any suggestions? ![]() I said a sorry state! ![]() Front of fuel filler flap ![]() Rear corner of hood (other side looks the same) ![]() ![]() Middle of the roof ![]() Top of fender My highest priority are problem areas on the shell, hood and fenders I feel are not as critical...
1980, 911 SC. Ex-US car in Sweden since June 2010. Insta: @911scowner |
dkbautosports.com
that car could get stripped with a razor blade .
i have stated this 100's if not 1000's of times . that is what happends when a sealer is not used . then you prep a car for paint most all paint CO's give you a window of about 12 to 24 hours to get color on the car if your not useing a sealer . the reason is the cut from the sand scratch will close back up and the new top coat will have nothing to bite into . over time it will want to peal and chips very ez . if you can get a top coat on the car with in that 12 to 24 hour window then there is no real need to seal . i how ever tend to seal most of the cars that go thru my shop . there is also the fact that many people will prep there cars with to fine of a grit of sand paper . this too will not give the top coats any thing to bite into . if i were you i would get a good car cover ! there is rust starting now so it will slow it down a little if you cover the car . use a real car cove made for the out doors not a plastic tarp . tarps are worse than just not covering the car at all . plastic tarps trap moisture under them . |
So there is nothing I can do other than a full respray?
Thanks for your reply /b
dkbautosports.com
i have stated many times in the past that there are many people that strip there cars down to bare metal when they don't need to . but this car is not that case ! this car would need to be stripped down to bare metal .
on the left fender were all the little surface rust is . i bet you will find rust like that all over the car under the finish . it's just starting to show it's self there 1st . many time you will get that from not useing a E-primer ( etch or epoxy )1st and just spraying your primer over a big spot of bare metal . that is why when ever you do a resto on your car if you have a area bigger then a quarter you should spray a coat of E-primer down 1st . my shop rule is any bare metal spot bigger than a dime . filler type primers do nothing to protect the subsraight ( metals) on a car . moisture goes right thru them . they tend to soak up moisture like a sponge . when you wet sand the filler primer on your car moisture is going thru it . what is saving the metal under it is the E-primer you put down 1st . the only true product the protects the metal on a car is the top coats and with that not even the base really only the clear or single stage thats on the car . now if you add a hardener to the base color that will also stop moisture from getting thru because you are cross linking the base coat components together . it's good for under bady parts but that too over time will brake down if you just did it to the outer substraights of a car . so if your looking to do a car in flat black don't think you can just add a hardener to the base and your good to go . |
