Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Tired Member
DaddyGlenn's Avatar
Question 3M strip caulk?
In another thread, it was said that 3M strip caulk should not be used because it is too soft and doesn't seal well.
I've got a few places I was planning on using the 3M product...between the front fenders and the tub, base of the rear quarter windows and where the door window frame meets the door.
Was the info in the other thread correct? If so, what should I use and where can I get it?
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 09-12-2012, 06:50 PM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
Thread bump. Hey Glenn, I am in the same position as yourself.
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 09-13-2012, 10:46 AM
Bird. It's the word...
Fishcop's Avatar
I used the factory Terrosen product (got it through Pelican)
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 09-13-2012, 04:34 PM
Tired Member
DaddyGlenn's Avatar
John, I can't seem to find it online. Can you provide a link?
Glenn
Old 09-13-2012, 06:10 PM
Fishcop's Avatar
I couldn find it either!?
I have the receipt at home, I'll track it down...
John Forcier
Old 09-13-2012, 10:54 PM
D911SC's Avatar
Is this it?
Porsche 911 & Carrera Exterior Trim - Page 10
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 09-14-2012, 03:50 AM
Tired Member
DaddyGlenn's Avatar
Originally Posted by D911SC View Post
Looks like you found it. Thanks!!
Glenn
Old 09-14-2012, 03:58 AM
D911SC's Avatar
Nice!
I used this. One tip is to cut a small hole where the fender screws go through. If you try and push the screw through the tape and tighten it you can grab the tape and it will turn with the screw, messing up the seal.
I'm not sure if I explained that well enough but I hope what I am saying makes sense.
I'm enjoying reading the progress of your rebuild.
Old 09-14-2012, 04:06 AM
Tired Member
DaddyGlenn's Avatar
Makes perfect sense. Thank you. You just saved me some frustration.
Glenn
Old 09-14-2012, 05:00 AM
Fishcop's Avatar
Yep, that's the stuff. Also referred to as "dum dum".
John Forcier
Old 09-14-2012, 05:05 PM
The Teroson product is now sold by Henkel and in the UK they only sell a 25 x 1.5mm thick strip and the PET shows the original as 25 x 2.0mm.
I bought a 5metre roll from Porsche and with Sales tax it was nearly $100, which is crazy.
When it arrived it was 20mm x 2mm,
I bought a 10metre roll of the 3M equivalent 20mm x 2mm and paid $25 and quite frankly can't tell the difference.
Old 10-05-2012, 02:20 AM
Fishcop's Avatar
Yep, not cheap. I wondered if there was better (cheaper) option.
John Forcier
Old 10-05-2012, 03:54 AM
We just use the 3M now and it works just as well as the Henkel Terostat 81
Henkel list 20 x 2mm but Henkel UK don't stock this size and would only sell a case of 100 x 25 metre rolls !!!
Old 10-05-2012, 08:09 AM
Classic's Avatar
A good trick when your fitting up your fenders with terostat, give them a spray with WD40, it will give you about 10 minutes to slide the fender back and forth, to fine the correct spot.
Classic 1969 911T
Old 10-08-2012, 01:00 AM
kkinzli's Avatar
Great tip about the WD40. I see myself using that trick soon!
1969 911T - The "Rat"
1997 A4 Quattro 2.8 (270k) - Black Kaniget - Dead but not forgotten
2010 Jetta TDI Sportwagen - Egg Butt (also Spewing Dragon)
2001 Eurovan Weekender - Bruni
Old 10-08-2012, 06:01 PM
Tired Member
DaddyGlenn's Avatar
+1
Glenn
Old 10-08-2012, 06:06 PM
Fishcop's Avatar
Yes, unfortunately Tony didn't pass that one before I did mine... Just as well I've got enough caulk to do it again
John Forcier
Old 10-09-2012, 01:13 AM
Classic's Avatar
John, you never asked.
If you need more I've got half a roll, you can have.
I got another one for you.....you need to put the windscreen wiper mechanism in before the dash, and windscreen!!
Got mine fitted today.
Classic 1969 911T
Old 10-09-2012, 02:46 AM
