-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   undercoat gun question (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/700257-undercoat-gun-question.html)
upwardr 08-29-2012 07:27 PM
I bought a spray gun for spraying the wurth undercoating used on the early cars.
It worked for the first tube and when I tried it a second time I can't get it to spray.
I cleaned it but am wondering if I am missing a pc off the nozzle, there seems to be a thread on the inside of the nozzle. Did I misplace something or is it something else I'm doing wrong,
Anyone have one of these can give me some advise.
Thankshttp://forums.pelicanparts.com/uploa...1346297142.jpg
http://forums.pelicanparts.com/uploa...1346297251.jpg
D911SC 08-30-2012 02:02 AM
Yes - there is a piece missing. There is a small 'nozzle' that screws into that thread.
D911SC 08-30-2012 02:09 AM
You can sort of make out what it looks like from this pic. I'd check the area where you cleaned the gun after it was working OK.
http://forums.pelicanparts.com/uploa...1346321353.jpg
upwardr 08-31-2012 03:33 PM
Thanks, I don't remember having that pc but I did probably remove to clean,
Just keep looking....
strath44 09-11-2012 09:19 AM
I've got a very similar one, actually I used about 3 in a few months!
They will still spray fluid out without the nozzle, albeit not as well.
If you are getting no fluid it is blocked - soaking in solvent will clear (but can damage it, wouldn't worry about that on this though).
If you get fluid and a poor spray pattern then you'll need to find the nozzle.
Even the budget manufacturers can be reasonable if you need to order one. Personally I'd not waste time buy a new one!
These are a nightmare to clean you really need to put the pick up tube in a tub of solvent / thinners and spray till its clear out the exit end!
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
