Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
upwardr's Avatar
undercoat gun question
I bought a spray gun for spraying the wurth undercoating used on the early cars.
It worked for the first tube and when I tried it a second time I can't get it to spray.
I cleaned it but am wondering if I am missing a pc off the nozzle, there seems to be a thread on the inside of the nozzle. Did I misplace something or is it something else I'm doing wrong,
Anyone have one of these can give me some advise.
Larry
1971 911T
1983 Envemo, Cabriolet
1989 Carrera Cabriolet
1969 912 Sun Roof
Old 08-29-2012, 07:27 PM
D911SC's Avatar
Yes - there is a piece missing. There is a small 'nozzle' that screws into that thread.
1983 Porsche 911SC Zinc Metallic - 3.2SS PMO's, Rennshift, 22/28 TB's, partially backdated interior. 28 month restoration now complete
2010 BMW 135i - Love it.
www.project911sc.wordpress.com
Old 08-30-2012, 02:02 AM
D911SC's Avatar
You can sort of make out what it looks like from this pic. I'd check the area where you cleaned the gun after it was working OK.
Old 08-30-2012, 02:09 AM
upwardr's Avatar
Thanks, I don't remember having that pc but I did probably remove to clean,
Just keep looking....
Larry
1971 911T
1969 912 Sun Roof
Old 08-31-2012, 03:33 PM
strath44's Avatar
I've got a very similar one, actually I used about 3 in a few months!
They will still spray fluid out without the nozzle, albeit not as well.
If you are getting no fluid it is blocked - soaking in solvent will clear (but can damage it, wouldn't worry about that on this though).
If you get fluid and a poor spray pattern then you'll need to find the nozzle.
Even the budget manufacturers can be reasonable if you need to order one. Personally I'd not waste time buy a new one!
These are a nightmare to clean you really need to put the pick up tube in a tub of solvent / thinners and spray till its clear out the exit end!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 09-11-2012, 09:19 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
