PhD on Pending Projects
Not sure what to call it...so apologies if the title is misleading.
Yesterday I took my '81 SC to the bodyshop for some rust repair, fitment of the RS bumpers, and complete respray (wohooo! ![]() I have a question regarding the back side of the door jam (part attached to the quarter panel). How is it supposed to look like? I see in the '81 that whatever part was there (inside when looking through the wheel well) looks like it rusted away. I need to know what part that is so that I can try to find it and take it to the shop guy. Thank you in advanced for your help!! ![]() The area circled in red (this is passenger side, but both side look the same): ![]()
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
Photos of what this area looks like in your car will also help. Thank you!
I had to make a replacement in my 66 swb restoration. Some pictures below that might help you see what you need. Not difficult to fabricate if you have a few basic metalworking tools and a MIG. Other than getting one off another car, I know of no source of replacements. It's important that you recover the two captive nuts you can see in the photos from the old lock plate, and that the plate with these nuts is free to move under the new cover plate or you'll have no adjustment option for your door striker plate. The base plate is attached to the B post with two (or three in some cases) spot welds. Locate these from the outside (door side) of the B post, drill them out and then you can make all the repairs on the bench. Then use the two (or three!) holes you drilled to re-install with plug welds.
If all this is gobbledegook to you, take it to your shop man and he should understand. If he doesn't take your car away! Mick ![]() ![]() ![]() ![]() ![]() Last edited by MTemp; 09-24-2012 at 10:38 AM.. |
Outstanding!!! Thank you!! Clearly understood what I need to do, thank you!!!
jdill
or you could just do it right and buy the lock pillar from the dealer,,,it appears yours has been spliced anyhow,,,great time to correct the car
79 928 euro -lint green/black leather 5 speed |
That was my initial question... if this part could be bought separately or if it was part of the door jam/lock pillar... From your post, it is part of the door jam... let me see how much those go for...
jdill
when the striker plate is rotted , the lock pillar usually is also,,,its better to adress it now if your bodyman is capable of putting it in
Leavitt Street Auto Body ![]()
jdill
the part from porsche lists at 200, shop cost is around 160 if thats any help aftermarkets are available but i would not recommend Leavitt Street Auto Body
89.00 from our host... Has anyone ordered this one?? Fitment issues?
Pelican Parts - Product Information: SIC-502-041-04
Registered speed offender
probably doesn't matter where the part comes from, it will still need some fitting and trimming. I believe the ones I installed were Stoddard... aftermarket anyway. Both sides went in just fine.
If you keep looking back, you'll never move forward. http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html |
![]() Quote:
Thread Tools | |
Rate This Thread | |
