Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
RustyWa's Avatar
Question New Paint Job....Now what?
Ok, picked my car up from the paint shop on 4/28, it's now 6/23.
It's a metallic paint with 3 coats of clear.
After the paint job, the painter did a sand and buff on the whole car. We had talked about having me do this step, but he ended up doing it on his own dime. He thought the paint should have gone on smoother.
In the sun the paint looks fantastic, but when you get the car in the garage and if you get the light just right, you can see some portions where he didn't buff it out enough. You can see in the clear coat where the sanding was done, just barely mind you and only if the light hits it just right.
So I'm thinking of just getting the whole car buffed again, the painter even recommended that. Is this something that can be done by hand or is that just a waste of time? Any recommendations on reasonable power buffers?
How long do I have to wait until I can start putting wax on the car?
Eric
'75 914 2.0L - Sold!
Old 06-23-2002, 12:23 PM
Brian993's Avatar
I would recommend hand polishing it a few times . It should clear up these minor issues you have. If you enjoy detailing your car, you will enjoy the results from polishing. I would look at the mequires products they sell some heavy and light polishes to serve your needs. I think you should be able to wax by now, however I would wait until the polishing is complete as it will only get in the way. Just my .02 . Your car looks great I love the color.
http://www.p-caronline.com/directory/brian993
Old 06-23-2002, 06:39 PM
RustyWa's Avatar
Any specific products?
Like Griot's Hand Polish, Meguires Show Car Glaze...... Something where even I could walk in to a store and grab the correct thing....
Eric
Old 06-24-2002, 02:33 PM
Brian993's Avatar
Griots hand polish is supposed to be good. I have the kit on its way. I will let you know. I use the 3M glaze from time to time and I like it. Theres so much out there. Its really trial and error as well as personal preference, I know that doest help but thats how I learned. Try a few different ones, I would start with mequires as they are very user friendly.
Old 06-24-2002, 02:56 PM
RustyWa's Avatar
I work real close to the Griot's store/warehouse. So I could just zip on over during lunch time and talk with them I guess.
Did you order the Porter-Cable DA polisher? I've heard many amazing things about that tool. (For those who say you can get it cheaper, and their products are..yada, yada, yada....I know. It's still good stuff.)
Eric
Old 06-24-2002, 03:02 PM
epbrown's Avatar
I don't disagree with that - their products are good, and there's some benefit to having it all in one place, tried and tested, especially if you're new at this. I just think that once you've gotten the hang of things, it's a good idea to shop elsewhere. I spent about 6 hours on my 2 cars yesterday, and went through a lot of various bottles, jars, and sprayers - the more serious you are about detailing, the more it's going to add up.
Emanuel
"Motorcycles... the cigarettes of transportation." Seth Myers
Old 06-24-2002, 04:01 PM
Warren Hall Student
Bobboloo's Avatar
Does the surface feel smooth with no overspray. If so then just start by compounding. 3M's Perfect-It II Fine cut rubbing compound works great after sanding. It removes all the scratches. Really flattens the paint. You could follow that with a glaze if needed. If you have any overspray then start with 2000 grit wet sand very lightly once over.(no elbow grease)
Bobby
Old 07-07-2002, 01:23 AM
RustyWa's Avatar
Bobby-
Everything is very smooth, no overspray. Should I apply that by hand or machine? (read, I don't have a machine....)
Eric
Old 07-07-2002, 10:23 AM
Meguiars #7 Glaze would be my choice.
Brian
Old 07-07-2002, 05:53 PM
If you have visible sanding scratches, buffing won't be enough. You will need to sand those out with finer paper, and then buff again. I'd recommend using 3M #2500 paper wet, with a drop or 2 of dish soap in your water bucket to help lube the paper. Then compound with Perfect-It II, then machine polish, then glaze. If you glaze now, all you'll do is hide the scratches, but they'll be back the first time you wash the car.
Old 07-09-2002, 07:31 PM
