914 door skin question
Hello there,
Have a question about the door and trunk skins on a 914.Are they suppused to be bonded to the inner support structure(Ex:the I beam running horizontally in the door)Im pretty sure the skins arent supposed to free float,as the gaps im seeing between the skins and supports are variable.If they are attatched,would a structural adhesive work,or could I mig them together. Chris |
dkbautosports.com
you should use a two part door skin adhesive like SEM #39337 on the outter edge of the door were it folds over the frame .
on the impact beam and spots on the frame to the trunk skin you use a two part flexible urethane foam sem part number 39357 . DO NOT try to use just any foam for that because it will srink and leave warping /wrinkle marks on the top sides of the panels . you have to use the foam that is made for the beams to skins . |
