Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Tim Boyer's Avatar
70' fixed door pocket removal
Hi,
What is the trick to removing the front fixed door pocket from a '70 911?
Thanks,
Tim
Old 07-06-2013, 10:59 AM
TR TR is offline
TR's Avatar
Remove rear pocket, put arm in hole below the arm rest and undo 10mm (I think ) nut from the threaded screw attached to the pocket. The front of the pocket can be accessed from the cabin it is the chrome phillips head screw. Let the pocket flop down and undo the four screws in the lower plastic hinges. Job done.
Old 07-07-2013, 05:49 PM
Tim Boyer's Avatar
Thank you TR!
I forgot all about that nut.
Tim
PS-I want to get the window raiser mechanism out of the door shell. Do you know the trick to doing this?
Old 07-14-2013, 01:52 PM
Tim Boyer's Avatar
Forget the last question!
It dawned on me that it comes out the bottom section of the door shell.
Tim
Old 07-14-2013, 02:52 PM
