Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
War584
Southern California - Targa Restoration Specialist
Any recommendations on a good shop that can source and install targa seals for my 1985.
I would replace them myself, however, I have read on the Pelican forums that the replacement seals available here and through other sources are larger than the originals, as they are intended for the 964, so they need to be modified to fit.
It looks like the PO did just that - they cut and glued the seals to fit so now the doors do not properly close - not to mention that the seals are cut on top and are too worn so they need to replaced. Given the cost, I want to do the project right the first time.
I welcome any suggestions on shops in my area, or where to buy seals that fit without any modification. Thanks.
Old 11-11-2013, 08:57 PM
I believe Dan Petchel at Cars Inc NJ carries the correct seals. carsinc@comcast.net
Old 11-12-2013, 01:20 PM
War584
Svendsen! - Thanks, I have sent an email and will let you know what comes back.
Old 11-12-2013, 02:05 PM
