Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
hemeoncdoc
complete 911 pan replacement advice
I need some advice on how to approach the installation of a new pan in my 1968 911. The factory pan comes with the lateral tank supports already welded on. As you may be able to see from the pics, the lateral tank supports protrude wider than the "arch" structure such that you cannot simply raise the pan into place. As it is all welded up from the factory, I don't want to cut off these pieces just to weld them back on - unless there is some other trick. I recognize that the new pan will need some areas "backdated" such as the fitment with the inner fenders etc. but this problem is far bigger. Thanks in advance!
Too many hobbies, too little time...
Old 11-24-2013, 10:53 AM
pors1968's Avatar
Ithard to have a good look if you have picture (more general) something like hole front panel.
Old 12-15-2013, 01:07 PM
Tags
floor pan , pan , sheet metal repair
