Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Fleabit peanut monkey
Bob Kontak's Avatar
Plastic emblems - re-sticking
I peeled the plastic name plates (Northstar/Deville) and plastic cadillac emblem off the trunk of a car I repaired. They were stuck on with a double sided adhesive material. When I used a heat gun to pull them off it bungs up the adhesive material.
I ran into the same issue with a 944 Turbo a few years back. I used an emblem glue on the 944 and it softened the paint so much that it left some imperfections.
Any idea of the correct product to use to re-glue/affix?
1981 911SC Targa
Old 12-11-2013, 11:41 AM
dkbautosports.com
962porsche's Avatar
you 1st should use a product like RM's 900 to remove the old adhesive from the panel and the back of the badge .
the best way is to get a clothe rag and soak it with the 900 and place it on the back side of the badge . it will soften the adhesive so it will fall right off if you just let it sit and keep the rag wet with the 900 . the same holds true for the adhesive on the panel .
once the adhesive is off get some double sided emblem and molding tape and retape the back of the molding ,badge or what ever . trim the tape so you don't see it sticking out all over . a #11 x-acto knife works best for trimming .
needless to say but measure just were the old one was before you remove it so you know just were is goes back on the car .
so your not reglueing the badge your replacing the material that was there to begin with .
regluing does not work and if you get it to stay it will still look like hell .
if the badge has thin lettering or script you just replace the badge it's not worth trying to put new tape in it . that would be fore badges like the ones that say Carrera on the 911's and the ones that say 944 , 968 and so on . they are not worth the time to try and retape them because they are dirt cheap .
Old 12-12-2013, 07:32 AM
Bob Kontak's Avatar
Originally Posted by 962porsche View Post
........get some double sided emblem and molding tape and retape the back of the molding ,badge or what ever
Thanks. NAPA has some double sided stuff. I will go check that out.
If RM900 is similar to the product you use to clean a panel just before painting, I have that.
I'll post a pic if I use it. (The tape)
1981 911SC Targa
Old 12-12-2013, 08:29 AM
dkbautosports.com
962porsche's Avatar
the 900 is a medium exploring slow drying pre body work cleaner .
I know it will not in any way harm plastic as for what you have I would check with a test spot 1st before you soak a rag and place it on the part .
Old 12-12-2013, 12:50 PM
Bob Kontak's Avatar
Agree with a test.
The emblem adhesive I mentioned above sure did not look that potent until the clear coat started melting.
Of course that was an Akso Nobel clear. :-)
1981 911SC Targa
Old 12-13-2013, 06:20 AM
dkbautosports.com
962porsche's Avatar
I had there paint system in my shop when I 1st opened 35 years ago .
I changed after 3 months because the system just did not work .
the color matching sucked ! if you had to repaint any thing there own products (base coat) would lift there own clears .
the baking times were 30 minutes not the 20 minutes of most clears out there .
you thing well 10 more minutes is not a big deal but when your baking cars in cold weather your heat bill for the booth goes way up .
Old 12-13-2013, 07:14 AM
Bob Kontak's Avatar
You have expressed your love for them in the past. I figured my comment would get you going. :-)
FWIW, I had no say in the paint.
1981 911SC Targa
Old 12-16-2013, 02:33 PM
