Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Overlap Percentage - Glasurit 22 Line
Recommendations for the overlap percentage of the spray pattern for single stage Glasurit 22 line ? I was going to use 50% but I saw the number 70% with a less wet coat thrown around. Any last minute recommendations ?
If it matters, color is orange over a white sealer.
Old 07-08-2014, 07:33 PM
dkbautosports.com
962porsche's Avatar
it's all how you spray !
when it comes to over lap gun speed and so on it's not what others are doing it's how you are comfortable behind the gun spraying .
I tend to do a 50% with a slow gun speed laying down the material as I want it to look .
other people that have painted for me do the 70% overlap with a faster gun speed .
there is just no right or wrong to the way you do your over lapping .
if any one tells you there is then they know less then you do about painting .
I like the 50% with a slow gun speed because I feel more relaxed doing it that way .
on KEMO's posting about classes I talked about stiff arm . that is from not being relaxed behind the gun .
being relaxed and being able to just take your time is when you will lay down a good finish .
Old 07-09-2014, 02:37 AM
Thanks 962. I will be applying your tips and a little paint on Saturday. I'll give a full report.
Old 07-10-2014, 07:43 PM
Robbbyg's Avatar
Ive never painted before and just started practicing on my rear fender im going from dark blue to a light blue color that I mixed up from various tins, end result is a mix I guess somewhere between minnerva and arrow blue, it looks great with black trim I call it marrow blue its one of a kind in the world , original is the way I like it.
First I used a brush and a small touch up paint gun, but I found the brush work needs more rubbing when dry so its best to use a gun,
If you use a gun and keep it clean and take your tie youll find your style, painting is the easiest thing on my car ive done , its lots of fun
I dont know about percentages and such, I only paint till it looks good , if it doesn't I try again, experience and practice is the best teacher
Wheels
Last row 1977 3.0 930 260hp built, still reassembling
Row 1998 996 MK1 3.4 296hp new daily driver
Old 07-24-2014, 09:18 AM
Nice
Nice job. Not sure about the mixing paint part though. Will make a nightmare later to match...
911SC 79, Aussie delivered, matching numbers, originally Cashmere Beige, painted black, Fibreglass update front, back and sides. Now going back to original restoration
2015 Jeep Cherokee Sport or the wife. Ford territory on gas (the work horse).
Old 07-26-2014, 12:29 AM
