Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
drola's Avatar
Rust Under Rear Window
what would be the best solution to fix this?
find a replacement piece? maybe fabricate?
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
2014 Ram 2500 Cummins
Old 01-26-2014, 07:33 PM
dkbautosports.com
962porsche's Avatar
the 1st thing that has to be done is pull the rear glass and strip the areas down to bare metal to see just what is under the paint .
after that you plan on the way it should be repaired .
Old 01-27-2014, 04:44 AM
wayner's Avatar
The best way to fix that is to remove all of the rear upholstery off of the seats and parcel shelf. By the time it rusts where your pictures show, there has been much more damage on the inside of the car than on the outer body.
You will also have to remove the rear window and fix the area that the glass sits in.
See this thread
Why windshield trim should be a regular maintenance item.
SOLD - 914 wide body hot rod
Old 01-31-2014, 12:33 PM
pors1968's Avatar
I think restoration desing have these parts.
Old 02-01-2014, 03:18 PM
drola's Avatar
Thanks for the tip. it looks like they have all the panels one would ever need
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
Old 02-02-2014, 08:19 AM
