Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Torsion Tube repair
Any advice on how to repair this and where to obtain a tube?
Hi, I have a very early '65 911, number 704 from the factory! It has had some work on the torsion tube in its part life. Since it is matching numbers and i am rebuilding from bare metal i need to do the job properly. I have a problem with the torsion tube.
1) it does not look correct since it has been patched
2) the patch does not look like it was done very well.
Could I replace just the middle section where the tube is indented? would a LWB fit Just the middle section?
where could I source a tube? Would fabricating one work?
Old 04-14-2014, 04:27 AM
pors1968's Avatar
No lwb tube the braket are not same location and look diff.If you chande the center you have to cut the rear seat to weld the tube.Were are you located.
Old 04-14-2014, 05:00 AM
Thanks, I am in South Africa. I expect to have to cut the seat to weld if I don't replace the whole crossmember/tube.
Old 04-15-2014, 07:29 AM
pors1968's Avatar
That the way to do it .
Old 04-15-2014, 08:40 AM
