Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
porscheguy47
Original muffler with dent
Is there any way of removing a dent from my original muffler? Can it be pulled out? It's about 8 inches long at the bottom beneath the mounting straps. Also, the exhaust tip seems to be welded on. Was this a factory thing?
Old 03-02-2014, 11:24 AM
pors1968's Avatar
Yes is the factory. look number 901....
Old 03-02-2014, 05:21 PM
yel911's Avatar
We used to get dents out of dirtbike exhaust by: plugging the inlets/outlets, except for one, and using a bicycle tube valve, (use a radiator clamp to hold the rubber on under pressure) fill the muffler with air and heat up the dented area with a torch. Go slow, because the added pressure makes it come out fast!!! Good luck.
74' 911 w/3.2L (sold)
95' 993 C2 Triple Blk Cab.
02 Honda Superhawk (sold)
2018 Toyota Tundra Limited
2004 CRF250X
Old 03-03-2014, 04:07 AM
super9064's Avatar
Most body shops have a tool that first spot welds small rods in the dented area; the dent is pulled and the rods ground off.
Rob
Old 03-27-2014, 01:04 PM
porscheguy47
Thanks for the replies. I've heard of the welded rod procedure but thought it might destroy the part code. I just might take a stab at the air pressure method. I'll post the outcome.
Old 03-27-2014, 05:48 PM
