Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Ferrino's Avatar
Paint Stripping Discs
Those paint stripping discs you mount in an angle grinder (as below) - do you think they could be used carefully to strip an entire car or would the heat inevitably warp the panels? I figure they're designed for stripping paint and to minimize heat build-up, so are they really much worse at building heat than a D/A sander? I guess a D/A spins a lot more slowly... Thoughts?
Old 08-05-2014, 04:04 PM
dkbautosports.com
962porsche's Avatar
they work ok for that as you know you have to keep moving with them not to build to much heat .
I personally like the orange stripper disc much better . they last longer and of you catch the edge of the disc unlike the black discs the will not fly apart .
if you need to machine strip a car use a old time DA sander set to the grind mode with 80 grit paper . it will cost much less then stripper wheels and you will not get the same heat build up as you would with a stripper disc . buy cheap ass sand paper as you will go thru it kind of quickly .
Lehigh valley abrasives . com has very good prices on da paper . I buy allot of my abrasives from them in bulk .
a 100 sheets of 6" DA paper is like 29 dollars .
I also buy all my cut off wheels ,grinding discs and so on from them on a monthly stock order for my shop .
shipping is quick and they have good pricing on every thing .
Old 08-05-2014, 07:51 PM
