'88 911 Repaint
Ready for the painter ... (sorta) ...
1988 911 Carerra 1982 Scirocco, Callaway Turbo Stage II |
I would remove the rocker trim, glass, crest on the hood and wiper arms studs (remove the nuts and rubber gaskets). Also it would be better to remove hindge pins/doors. Still a ways to go, IMO. Sunroof area needs attention, remove gasket, I could go on. Doing the car in pieces would do a better job.
74' 911 w/3.2L (sold) 95' 993 C2 Triple Blk Cab. 02 Honda Superhawk (sold) 2018 Toyota Tundra Limited 2004 CRF250X Last edited by yel911; 10-07-2013 at 06:19 AM.. |
I did remove the washer arm studs, or at least anything making contact with paint.
Anyway, I'm having the car repainted at DJ's Auto Body. He's going to take off the remaining stuff. I just took off as much as I could to save some $$$.
The glass is easy to remove, just push from the inside-out. Apply equal pressure and have someone on the outside pulling, gently. One less thing the bodyshop can charge you for. I look forward to see your progress!!!
74' 911 w/3.2L (sold) 95' 993 C2 Triple Blk Cab. 02 Honda Superhawk (sold) 2018 Toyota Tundra Limited 2004 CRF250X |
ClubEuroMafia
Nice work. Any progress at the Shoppe?
Ready to come home!
![]() Some assembly required
![]() Rust repair, worst spot. Typical problem area.
![]() And patch in.
