Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
BMW Roundel disconnecting wiring harness
Help, I am replacing the door on my 1997 bmw z3. It is unattached except for the wiring harness going through the door to the body. I assume there are some clips to move, but I can't find any. Any suggestions?
Old 06-24-2014, 06:53 AM
dkbautosports.com
962porsche's Avatar
there should be a U shaped clip that holds the two half's together . you have to take a little flat blade screw driver and lift up on the center part of the U . this clip will release the halfs .
you can see the black clip in the photo kind of facing you lower part .
Old 06-24-2014, 08:39 AM
worked, thanks!!!!
Old 06-24-2014, 09:37 AM
dkbautosports.com
962porsche's Avatar
any time
Old 06-24-2014, 09:59 AM
