Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
How do I attack this dent?
Unfortunately I bumped into the fender of my 930 so now I have to make it right again.
Dammit! by willtel, on Flickr
I have some body work and paint experience so I'm not too concerned about it but this will be the most significant dent I have tackled. With one this severe what do I do first? Go at it with a hammer and dolly or use a stud welder and slide hammer followed by hammer and dolly work?
1987 GP White 930
1977 Ford Bronco
Old 09-23-2014, 08:13 AM
Send a message via Yahoo to rgofast
That is definitely stretched, so you will have to do some shrinking
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke
1973 1/2 911T S optioned sunroof coupe (in progress)
1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels
1999 996 Carrera Cabriolet
Old 09-23-2014, 10:40 AM
Without a doubt.
Do I start with shrinking to try and get it to come back into shape? I have some shrinking hammers I can whack it with. Would it be better to try to use a shrinking disk?
1987 GP White 930
1977 Ford Bronco
Old 09-23-2014, 11:46 AM
paint huffer
scotty b's Avatar
knock it out as far as you can with a stud welder if available, or just a hammer, then work it with a hammer and dolly, then shrinking disc. This one wasn't as bad as yours, but shows what can be done with minimal work and no filer needed
993 collision damage
http://kahikocustoms.com/auto-projects
Old 09-24-2014, 06:23 PM
Nice work scotty! That gives me something to strive for. I'm going to pick up a stud welder for this as I have a dent in the door jamb of my daily driver I can also use it on. I'll post some pics once I get started.
How was blending the paint on that 993? I'm really concerned about getting the white to match but I would assume yellow is in the same realm.
1987 GP White 930
1977 Ford Bronco
Old 09-25-2014, 07:23 AM
paint huffer
scotty b's Avatar
Single stage Spies. Not too bad to blend
Old 09-25-2014, 07:53 AM
dkbautosports.com
962porsche's Avatar
you will find a shrinking disc will not work as well as they do on panels that are flat or have simple shapes to them .
in your case you have compound curves and the body line of the wheel opening .
you can easily get to the back side of the fender once the wheel is removed to work the panel with a hemmer and dolly .
there is no need for using a stud gun on this repair as you can get to both sides with nothing in the way .
when it comes to matching the color I would go to your area BASF glasurit paint store .
I'm guessing the color code is 908 on your car there is I think 7 color chips to look at on that color . BASF has what are called color max color chips they are real spray out done for you with real paint right from BASF . there is not a need to go buy any color and do spray out wasting your money and time . just have the paint store look up the color code and pull the chips you need to see . hold them up to the car in the sun and shade find your best match and have them mix the amount of color you need for the repair .
you have a dent in the middle of the panel so there should be no reason to blend into the panels next to the fender .
Old 09-26-2014, 05:03 AM
less I know,more I learn
Backyardbodyman's Avatar
That's a nasty looking dent. The easiest way to fix that dent is replace the fender with a good straight one.That doesn't mean you can't fix that dent.Forget the stud gun,that's for areas you can't get at.Still a great tool to have,can be used for shrinking.You can work that out with a hammer & dolly.Take your time working it out,little by little you can work the metal straight so you don't need to much filler.This forum is awesome.There's pros here that will help people with anything.Cheers
Raymond
Old 10-23-2014, 02:08 PM
Some days you just have to head out to the garage and beat your Porsche with a hammer!
I got a decent amount done with hammers and dollies. I've ordered a shrinking disk that I plan to attack it with next. Dent be gone!
IMG_2915 by willtel, on Flickr
[IMG]IMG_2919 by willtel, on Flickr[/IMG]
IMG_2926 by willtel, on Flickr
IMG_2928 by willtel, on Flickr
1987 GP White 930
1977 Ford Bronco
Old 01-06-2015, 12:26 PM
Bye bye dent ".
Old 01-07-2015, 02:20 PM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Scotty... excellent work on the yellow 993!!! amazing that you were able to get that smoothed out without using any filler.
willtel, looking good as well, thanks for posting
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 01-08-2015, 01:35 PM
sugarwood's Avatar
Can someone explain the main steps to using these so called hammer and dolly?
You just hammer from the inside, and use the dolly blocks to shape the fender?
Then you will have a rippled fender.
Then you just grind it down smooth?
The shrinking disk gets rid of the ripples?
1986 3.2 911 coupe.
Old 01-08-2015, 05:05 PM
Black and Blue
Kemo's Avatar
sugarwood,
im no pro, but the hammer and dolly takes a bit of practice and some patience. Lots of different techniques and dolly types. the talented guys can make dents like you see in this thread disappear with little or no filler at all. Im not there, but I do have a lot of respect for those who have the skill. There are a few videos on Youtube you can scour. It would take a long time to answer your questions and I would probably botch a few of them. Hopefully some of the pros here will chime in. In the mean time, here is a good video
https://www.youtube.com/watch?v=rt07pLebQwQ
Kemo
Old 01-09-2015, 08:34 AM
sugarwood's Avatar
Great video Kemo. Thanks for sharing.
This seems like a very different approach than drilling holes and pulling with the slide hammer.
1986 3.2 911 coupe.
Old 01-10-2015, 06:55 AM
willtel,
Impressive work on the dent!
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
Old 01-10-2015, 08:30 AM
Sorry this isn't a skill that can be taught on a forum.
you need to get the tools, Good tools not junk from harbor freight.
Then get some old fenders from the junk yard and get to practicing.
Old 01-26-2015, 07:47 PM
Discseven's Avatar
Nice work WILL.
Karl ~
Current: '80 Silver Targa w /'85 3.2
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver 930. '79 Black 930. '79 Anthracite 930.
Old 02-11-2015, 07:01 PM
It is getting close now. I picked up a slapping spoon and it is starting to come together. I still have a few little low spots to bring up.
IMG_2941 by willtel, on Flickr
IMG_2934 by willtel, on Flickr
IMG_2933 by willtel, on Flickr
IMG_2940 by willtel, on Flickr
1987 GP White 930
1977 Ford Bronco
Old 02-14-2015, 04:28 PM
sugarwood's Avatar
Left us hanging!
Where's the final product ?
1986 3.2 911 coupe.
Old 08-24-2018, 07:12 AM
Jon Bingham
Send a message via Skype™ to TheMetalSurgeon
now you can use a shrinking disc to blend and 'flow' the light line.Dont lean too hard into the panel ,light pressure and keep moving over the panel.
Old 08-24-2018, 08:23 PM
