Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
War584
1985 Targa - Door rattle / Glass?
My targa doors make a metalic rattle when I hit bumps as if the glass or window internals are loose. I notice a similar sound when I close the door. It does not close with a solid sound like some Targas of the same vitage, but sounds like something is loose on the inside - so the closing sound is hallow sounding with a rattle.
The windows operate smoothly and evenly so not sure what this could be other than maybe the internal felt which is worn. Any thoughts would be appreciated.
Old 10-10-2014, 02:49 PM
dkbautosports.com
962porsche's Avatar
that off the inner door panel and look to see what is going on .
it could be a number of things so any answer would be a guess until you pull it apart and see .
Old 10-10-2014, 05:16 PM
I just had a similar rattle, took door apart 2 times to no avail. Then I decided to check the mirror, it was loose, tightened it with an allen and problem solved. Worth a quick check. Good luck, Tim
Old 10-13-2014, 09:07 PM
