Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Found great cheap door weatherstripping substitute!
Carrand 01058 - Weather Strip | O'Reilly Auto Parts
The felt weather stripping that runs along the roofline between the door started whistling. After 30 years, it was pretty ratty on my 930. I bought the Porsche rubber door seals, but wanted something better to replace the felt.
The Porsche replacement was about 100$ for both sides. Ouch. Plus, there must be something better.
Searched the net and found the modern equivalent for $12. Just installed it, and it fits and works great. Rather than screwing it in, it gets glued in. Perfect seal, super quiet, no wind noise.
It's a nice modern update, and it's cheap. Looks good to. You can't tell it's been upgraded unless you really look. Also, it can fill a larger gap, which really helps along the front of the door.
Highly recommended. Hope this helps someone. Pics to follow.
Bo
Old 11-02-2014, 06:49 AM
shogun's Avatar
Here some pics on an E36 DIY fix
DIY: $20 E36 coupe door weatherstripping
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
http://twrite.org/shogunnew/topmenu.html
Old 02-01-2015, 07:26 PM
Yep, same stuff I used. It looks great, and is holding up really well. Much better than the original stiff porsche weatherstrip.
Fo anyone looking for a quick weekend project, this is it! Car is much quieter inside now.
Bo
Old 02-02-2015, 06:23 AM
