Senior Member
What kind of paint should I use??
Restoring my 1980sc and wondering if I should stick with glasurit 22 line or go to a base/clear. I have never painted a car with single stage paint before wondering how it is to buff/sand/polish and also if I can just use a good two part epoxy primer
dkbautosports.com
as for to use SS or BC if it's not going concourse then it's up to you .
SS to BC is no harder to color sand and buff it's just different . the same can be said for applying the two . when your talking epoxy primer there are many different types and uses of them . more details of just what epoxy your thinking of and or it's use you would need it for would be a help . |
Senior Member
I thought about using ppg' shopline epoxy then a 2k primer then using the epoxy as a sealer?? Then an acrylic urethane base coat. Followed by a high voc clear
dkbautosports.com
you no longer can buy high VOC clears because of the national VOC rules .
in fact you can't buy any high VOC products at all . they now are of low VOC . MOST base coats are of polyester based not acrylic as acrylic based product when it coes to base colors are of lower grade . they do not hold up as well ! CO's like house of kolor still use acrylic as the cost to reformula all there colors to a better more up to date product is not needed for there product line of coating . |
Senior Member
Ok so could you recommend a product line/process to paint my 1980sc. It needs to be taken down to bare metal and sprayed black the original color.
dkbautosports.com
what's the color ?
Senior Member
Color is black I figured I would stay with the original.
dkbautosports.com
more questions .
what is the spraying environment you will be painting in ? your garage ? booth ? what is your use for the car when finished ? every day driver ? weekend ? cruise nights ? shows ?concourse ? |
Senior Member
Not sure where I will be painting but garage is probably a good answer. Just a driver
dkbautosports.com
I would go down to Liquidz auto body supply on Edison st Syracuse .
they are a BASF jobber and should have the RM paint line . I would use the EP 789 epoxy primer for going over bare metal . for a filler primer I would use the DP20 . for a wet on wet sealer you can use the EP 789 . for base color I would go with Diamont base and then one of the RM urethane clears . I would do it in B/C simply because if your not spraying in a booth you may get some dust in the base . if you do you can give it a lite sanding and go back over it with more base . |
Senior Member
Thanks for your time appreciate it
Senior Member
One more question what size tips for the epoxy primer,build primer,sealer,base and clear. Was thinking about buying a devil bliss finishline gun with different tips. Can I use a harbour freight purple gun for the primer??
dkbautosports.com
the finish line guns for the price is a very good gun .
a 1.3 or 1.4 will work for the EP , base coat and clear . a 1.6 to 1.8 will work for the DP primer . 1.7 or 1.8 being best for primer . just clean the gun real good and you will be just fine using the same one . a 1.3 would be the best size for a all around ep base and clear gun . |
For a home job find the simplest system there is so you aren't buying different hardeners and reducers for each stage.
I hate to plug PPG but they have very user friendly lines with hardeners and reducers (oversimplifying here) that can go from primer to clear. PPG NCP is an etch primer that can also be a surfacer and also a sealer depending on what is mixed into it. You buy one gallon and mix the appropriate hard/redu in it. NCP fills fairly nice and sand easily. I would also go with the single stage as again you are cutting down on product. to me a single stage black always looks the cleanest. If you don't want to be 100% color match then House Of color also has great system and a really nice black. Stay away from HF there are low cost guns like CAT that really cut down on overspray and sell in kits with caps and needles to go from prime to color. Good luck. |
dkbautosports.com
I do not agree with to much of what was stated !
basf also crosses the reducers and hardeners . as for SS saving you any thing NO SS costs the same as BC . you will not save any thing . as for house of Kolor it's a very out dated product and is of a very low grade . it's acrylic based . if you want a low cost low grade equal to house of kolor get limco or Omni line . at least limco is a urethane based product . being a airbrush artist i have used house of kolor 1000's of time and have there paint system in my shop . all i can really say about there products is they suck . if you get dust in ss your stuck with it . does ss offer more depth to colors like black well yes to a point . but there are also big pluses to bc . i would stick to the finish line or start line guns . there offer very good quality at a very good price . from now to the end of time you will be able to buy parts for it at just about any jobber (automotive paint store ) |
You mentioned OMNI...
Is it really that bad? Our local paint place carries it, was going to use it for some black touch up and blend... What makes a paint line a lower grade? Is it the final appearance? Ease of use? Durability? Also, what do you think of the paints that EASTWOOD carries? They seem to have great reviews... Thanks |
Senior Member
If I'm doing a bare metal re spray on a targa how much paint will I need?
dkbautosports.com
are you doing the Jams and undersides of lids?
dkbautosports.com
the chemical make up if the product is what determines the paints grade . Alkyd is the lowest with acrylic being just slightly better . that does not mean that all acrylic based products are of low grade . you can have acrylics mixed with other based components like urethane this brings the grade to a much higher level . calling some thing user friendly is kind of a useless term . I use it my self but it has to do with more then one of the parts of a product . most people will use the term as being friendly to spray . this is only one out of many aspects of a product line . all paint systems will work and be user friendly if you go by the system stick to the system and go by the TDS of the system . products lke alkyd and acrylic do not and can not offer the same UV protection as say a urethane or polyester . the biggest reason is the plastic base component of the two urethane and polyester . one of the cars I own is a rally car when it's not being used it just sits out in the weather . I painted it 10 12 years ago with alkyd enamel the lowest of the low grade paints . the car still looks good and to get it to shin all we do is run the buffer over it . I also own a 944 track loaner (I let new drivers to the track use) that car also sits out side all the time . I painted it 8 years ago with polyester base urethane clear and to get that car to look good all we do is wash it . it's never needed to be buffed yet . both cars are dark blue solid colors . if you own a car that you don't drive much and sits in a garage most of the time in reality you could use a lower grade product . it's not seeing any heavy use or weather . most of the time the owners will keep it clean and by doing so the finish is not going to go thru the same as a car you would be using more . I own a 1988 countach with the original red acrylic lacquer finish on the car . there is nothing wrong with the finish at all and still looks as good as it did from day one . the car just does not see any weather at all and is in a climate controlled garage . so when some one states they used a lower grade product and it's holding up great . you have to think about the environment the car is seeing . |
Bo |
