Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Removing paint from rubber
Can anyone tell me how to remove paint from the rubber trim? No one is able to help me here. When I bought my car the rubber trims were painted with the rest of the car. I have been told to only way to remove is to use a razor blade. There must be some stripper or something that will work without destroying the rubber.
1969 911, resurrected into Widebody Slantnose Cabriolet
Old 03-10-2015, 06:10 PM
dkbautosports.com
962porsche's Avatar
if you use a razor blade your sure go to screw the gasket up .
post a photo of what you need to do .
Old 03-10-2015, 06:53 PM
Bellows, rubber on front clip, rubber on running boards.
Old 03-11-2015, 05:16 AM
dkbautosports.com
962porsche's Avatar
there are products like SEM # 39913 urethane bumper stripper that will strip the finish off .
the down side is that to get the paint to stick they may have sanded the rubber pieces .
if that was done and you just want them black raw rubber your kind of screwed .
how ever you could repaint them in some thing like a trim black after you strip them .
Old 03-11-2015, 05:40 AM
Ruf930's Avatar
Ive had same problem ,
Quickest and easiest way is to use thinners on a rag and simply/carefully wipe the paint off, it will leave the rubber like new
Old 06-30-2015, 12:16 AM
