How long before applying graphics on new paint
We are almost at the paint stage in my backdate 73 RSR project. I have Carrera vinyl graphics to apply. How long should I wait before applying them on new paint?
you should wait until you can press you finger nail in the surface and it does not leave a nail mark .
if it leaves a mark the finish is still out gassing it's solvent's . this will give bad adhesion of the vinyl it could lead to the vinyl delaminating or bubbles in the vinyl . |
Thanks for the quick reply. Again 962 to the rescue. Is it normally about 48 hours or a week. Or ???
it depends on the cars panel temperature how much material (coats of paint) are applied and type of material .
most cases at about 70 degrees your looking at 48 hours . I always give it the finger nail test . in my area of the country we may have day time temps of 70 but at night the temp will drop down to 50 degrees . this will add curing time to a finish . it's also the temp of the panels not the air temp you have to go by . the air temp maybe 70 degrees but the cars panel temps could be higher or lower then the air temp . |
Thanks again. Good info.
| All times are GMT -8. The time now is 05:22 PM. |
