Coating Backside of Fenders & Quarters
What combination of coatings is typically used for the backside of front fenders and rear quarters? I'm going to be welding on turbo flares (therefore introducing a welded seam) and am wondering what the best way to protect the insides is. Something like epoxy primer and UPOL Gravitex?
dkbautosports.com
after we dress the welds on the under sides we then use epoxy primer mixed as a surface spray one or two medium coats .
then let it dry and sand the epoxy with a red pad and with a two part seam sealer like SEM's 40377 we will spread or brush it over the seams getting in any nooks . then let it dry and chip guard the undersides of the panels . we use the U-pol for the chip guard . you don't have to seam seal over the epoxy primer but we do as it's the under sides of the QTR's so we want all the protection we can get on the bare metal . |
Awesome, thanks! Presumably the 3M 08308 2-part seam-sealer would be appropriate too? Reason is I just purchased the 3M 2-part applicator gun for their panel adhesive.
3M Heavy-Bodied Seam-Sealer |
dkbautosports.com
my guess is it would be just fine . I thing the 3M is a non sagging and that's what you would want to use so it does not end up dripping on the floor .
u-pol
which u-pol product and what color do you use for the undercoating?
the bedliner U-Pol Products 0825 RAPTOR Black or U-Pol 722 Gravitex Stone Chip Protector, 1 Liter Bottle, White? or? thanks
1975 911S Targa Silver Anniversary Edition |
dkbautosports.com
we now use the U-pol gravitex white tinted to match the old OE color .
bed liner products do not work very well for chip guard material . you would think it does but it will not hold up as well as chip guard does . |
tint
not sure what my under color was is it yellow or is it to match the color of the car?
dkbautosports.com
it should be a very light beige color .
by now it will look like yellow as the color faded over time . |
example of color
any pictures of the color that we can use to tint the white too?
Wer bremst verliert
How about on the underside of glass or CF fenders? What works to eliminate or minimize crazing later on should rocks get kicked up inside?
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
I would rather be driving
What is the difference between the UPOL Gravitex 0721 and 0722? Is this just a replacement line product? 0722 is more expensive.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
dkbautosports.com
the difference in the numbers is what color it is .
they have white , black and gray . they are all the same price no matter what color you buy . |
dkbautosports.com
962, do you have any tips on how to mimic the texture of the factory chip-guard, using the Gravitex and their "schutz gun"? e.g. psi and distance from surface? Thanks!
dkbautosports.com
sadly no I do not !
I don't like there gun and the guns like it . the gun I own for doing chip guarding is totally adjustable having adjustments more like a paint gun does. being adjustable you can change the way the product will lay down and it's texture . |
Occasional User
Like 962, this guy Darryl is a guru. I think Darryl is a sometime poster at Pelican, his website is amazing, and his attention to detail is impressive. In his rust repair here he shows how he gets the texture.
DarrylD's Porsche 912 Project Page - Phase 8: Right Longitudinal Channel Repair
Vince 2015 Boxster S, Black & Black 1989 Carrera Silver Coupe, Silk Grey - sold 2009 Cayman S White, Full Cocoa - sold 1972 911E Silver Coupe, Pepita & Black - sold |
