Can I use limco 800k in place of dp20
I didn't want to spend $300 for a gallon of primer is it ok to replace dp20 with limco 800k
it sure is . the 800k is a ok primer doesn't have the hold down DP20 has so just make sure you do your final sand by the book . or TDS !
we use 800K quite often with no problems at all from it . |
| All times are GMT -8. The time now is 09:22 PM. |
